Stock Valvespring ?
Old Sep 22, 2006 | 12:03 AM
LS1-STANG's Avatar
Default Stock Valvespring ?
Are the stock valvesprings that bad in a LS1 eng ? Does a stock car (meaning stock head & cam car) really pickup MPH/ET with a set of Comp 918s ?
Thanks Jim
Old Sep 22, 2006 | 12:26 AM
The stunningman's Avatar
you can pick up horsepower by better valve control. meaning you can twist the engine harder and not float the valves.
Old Sep 22, 2006 | 12:33 AM
Ls2Sonoma's Avatar
you can also shorten the life of your valve train by putting stronger springs such as the 918s. stock motor, id use the 915s at the most
