Gaining HP naturally aspirated?
Old Sep 24, 2006 | 11:56 PM
import slayer's Avatar
Question Gaining HP naturally aspirated?
All of my mods are in my sig. other than long tubes and a LS6 intake what else can I do to gain some good HP staying N/A
Old Sep 25, 2006 | 12:04 AM
LS1IMPULSE's Avatar
ported fast 90mm. NW 90mm
underdrive pulleys
electric water pump
Just curious do you have a dyno grapgh for the mods you have now?
Old Sep 25, 2006 | 03:17 AM
300bhp/ton's Avatar
What are Stage 2 heads?
Better intake, better exhaust, better heads, wilder cam (yes I know ), larger displacement, higher SCR/DCR, a tune.
Plus there's always things like weight reduction and chassis mods which help deploy the power better and make more use of it. Body mounted torque arm, LCA, SFC, etc.
A 150 shot of nitrous would also see a significant gain in HP. Ok it's not n/a but unless you are racing in a class which prohibits such things who really cares. HP is HP, and the person with the most usually stands the better chance of being faster.
Old Sep 25, 2006 | 06:05 AM
BLKWS.6's Avatar
Lol, I thought this was a thread started by an LS1 noob/former mustang owner asking if they could make hp NA
Old Sep 25, 2006 | 07:13 AM
john563's Avatar
Now when you say N/A that stands for nitrous assisted right?Because a 100 shoy would be a nice kick.
Old Sep 25, 2006 | 07:28 AM
slow trap's Avatar
with a cam that size and decent heads a 90/90 with a set of lts and a tune will net you some decent gains and the ud pulley should give you alittle also.as 300bhp has asked you may have stage 2 heads but some stage 2 heads are totally different than someone's else stage 2 heads and if your dcr is low with those heads a head with a smaller combustion chamber will benefit you.
Old Sep 25, 2006 | 07:38 AM
Old Sep 25, 2006 | 12:39 PM
ArrestMeRed99Z28's Avatar
+ 1 for nitrous, and if you get a plate system (NOS and Nitro Dave both make these kits) it will give you 2-3hp because it is a throttle body spacer
