What cam?
Old Sep 25, 2006 | 04:25 PM
SSmokin99's Avatar
Default What cam?
What cam should I get? I live here in California so ...you know how that goes. My friend has a 230/230 114lsa with some LS6 heads(i think) and full exhaust. He's a A4 and he said he has like 440 rwhp. Anyway that's about the rwhp I want so I wanted some suggestions from you guys. What heads should I go with? AFR 205? What heads will I get more power out of?
Old Sep 25, 2006 | 05:42 PM
s346k's Avatar
Originally Posted by SSmokin99
My friend has a 230/230 114lsa with some LS6 heads(i think) and full exhaust. He's a A4 and he said he has like 440 rwhp. What heads should I go with? AFR 205? What heads will I get more power out of?
i'd ask to see a dyno, that's an awful high number coming from a mild head/cam combo through an a4. 205 afrs are good for making power because they can be milled to achieve 59cc combustion chambers without compromising a ****-ton of ptv. i think an lg setup (x3+afr205) would be perfect for you, but would be heavy on the wallet. that is a proven setup that will get you good numbers, though.
your car with that cam + ls6 heads would probably yield 415-425 rwhp. this is assuming supporting bolt-ons and a 10 bolt rear.
Old Sep 25, 2006 | 05:45 PM
SSmokin99's Avatar
What would I make with a G5x3 cam and AFR 205 heads? What would it cost for parts and labor? Also what are the #s on the cam?
Old Sep 25, 2006 | 07:41 PM
SSmokin99's Avatar
Old Sep 25, 2006 | 08:20 PM
s346k's Avatar
search dude...there are all kinds of numbers from that particular combo and MANY MANY MANY more. i'm not going to do your homework for you.
Old Sep 25, 2006 | 08:56 PM
SSmokin99's Avatar
WhOa ok, but there's no need to act like a dick! Thanks for your info anyway
Old Sep 25, 2006 | 08:59 PM
s346k's Avatar
sorry, i'm not trying to come across as a dick, but at this rate i will have your combo mapped out for you...when you don't even know the specs of the cam. i want you to learn, not become another moo cow in the scheme of cams. sorry if you took it the wrong way.
Old Sep 25, 2006 | 09:04 PM
waterbug1999's Avatar
That seems kind of high for an A4 with that set up.. You sure its legit?
Anyhow, I dont think your X3/AFR combo would even pass the sniffer test either..
Old Sep 25, 2006 | 11:07 PM
SSmokin99's Avatar
Its cool man
Old Sep 25, 2006 | 11:08 PM
SSmokin99's Avatar
Not sure if its legit...I just took his word for it. Well If it doesn't pass I can have my cousin hook me up because he does that stuff. Wondering what RWHP I can get out of that set up
