Critique this cam
Stock G5X2 specs (for comparison purposes)
232/240 .595/.608 112 or 114 LSA
I'm thinking of going similar, but with an LSK lobe on the intake (instead of an XER like the G5X2, for more power throughout the powerband).
231/240 .643/.608 112+2 (110 ICL)
Heads will be Livernois 243s milled .030" for 59cc chambers, if my calculations are correct.
Single patterns are sure working well (like the 224 you had). Are your specs set in stone? Having that extra exhaust duration if not necessary will result in more overlap and less overlap might be advantageous for the street when talking about a 23x/24x cam.
Ben T.
