ati pulley help
Old Oct 2, 2006 | 05:58 PM
pewter 01 SS's Avatar
Default ati pulley help
well finally i got the car started after alot of problems.. anyways the freakin front cover seal leaks.. .. i have the ati balancer and it was probably the hardest pulley to install ever.. i tried boiling it like it said in the instructions but didnt help much. any one else has a better idea, i ve heard heating it up with a torch.. the 1st time i put it in it took alot of effort and a big *** compresser and torque gun..
Old Oct 2, 2006 | 06:39 PM
vettenuts's Avatar
The interference fit requirement for the ATI is 0.0007"-0.0009". Did you measure your crank and pulley hub? They require honing if they don't fall into this range, which is likely the reason you had such a difficult time installing it. Mine went right on using a very small amount of anti-seize per the instructions, even though my fit was off by 1/10,000 with an interference of 0.0010".
Old Oct 3, 2006 | 01:10 PM
so basically measure the diameter of the crank and the pulley hub and if doesnt have clearence of the measurement you said hone the hub right? i didnt want to do anything to the hub without makeing sure what to do.. hey ive also heard that people used a torque to heat up the pulley inorder for it to slide in easier.. heydid you use a key to put on the pulley and crank?
Old Oct 3, 2006 | 01:11 PM
by the way what did you use to measure the hub/ crank?
Old Oct 3, 2006 | 05:59 PM
vettenuts's Avatar
A machine shop can measure the hub internal diameter as this will require some special tools. I measured the crank snout with a micrometer that measures in the 10,000's. The hub diameter should be smaller than the crank, by 0.0007"-0.0009". ATI will hone the hub for $40, but they are in Baltimore, which is a long ship for you from the west coast. Please note, I have the steel hub, if you have the aluminum hub the instructions and fit are different.
Yes, I also pinned the crank with the ATI kit. I then used the ARP bolt that goes on with a lower torque value and is lubed with their lube so later removal won't be an issue. I also made a tool to press on the hub from threaded rod.
Do you have the ATI instructions that came with the pulley?
Old Oct 4, 2006 | 08:43 AM
yeah i do have the instructions that came with it but unlike you i have the aluminum hub which says it will expand when heated up, but it just didnt seem right going in so hard
Old Oct 4, 2006 | 11:27 AM
vettenuts's Avatar
I don't remember, but I thought the aluminum hub also specifies an interference fit but the interference numbers were larger.
