Iron 402 and Stock Heads?
Old Oct 4, 2006 | 06:11 PM
Kakarot2569's Avatar
Default Iron 402 and Stock Heads?
I have a 99 Trans Am that I just hydrolocked the motor on. Insurance is covering the cost of a new motor, I wanted to put an Iron 402 in it and I have a set of GTP Stage 2 Ported 5.3L heads sitting in my garage I never got around to installing. Can I use these heads as a budget solution? I was not sure because the Bore is bigger.
Thanks!
Old Oct 4, 2006 | 06:49 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Yes, the heads should work just fine. They may not be optimum, but they should work until you can get better heads. 4.8, 5.3, 5.7, 6.0 and 6.2 L types of heads should work for your engine because all are the same 4.4" bore center and your 4.0" bore should accomodate the valve diameters.
Steve
Old Oct 4, 2006 | 07:01 PM
Black Sunshine/ 00SS's Avatar
Shouldn't cost much at all to have the heads taken out to a 4" bore, from a local machine shop. They will flow better also. Good luck.
