Should I be concerned with this???
Old Oct 5, 2006 | 01:10 PM
1stz06's Avatar
Default Should I be concerned with this???
Take a look at the top of my pistons. They are nasty.
Old Oct 5, 2006 | 01:20 PM
PREDATOR-Z's Avatar
Normal, just clean them with brake cleaner, or gas (I use both)
Old Oct 5, 2006 | 01:33 PM
1stz06's Avatar
You da man Predator!!!
Old Oct 5, 2006 | 02:14 PM
PREDATOR-Z's Avatar
you're welcome.
>don't use any abrasive material
>Bring the piston to TDC, makes life easier
>There is a product called "piston clean" on the market that you can use as well.
Myself I use first brake cleaner and let it soak for a couple of minutes, use soft cotton rags and elbow grease, then I finish them with gasoline and voila.
> mist the piston lightly with motor oil while rotating crank to lubricate cylinder once piston cleaned and moving to next one, as they might be dry from solvents used.
Old Oct 5, 2006 | 02:20 PM
LS1INSIDE's Avatar
i've heard the stuff used to clean ovens works,
Old Oct 5, 2006 | 02:34 PM
TchargedLS1TA's Avatar
If your gonna use brake cleaner, make sure you do it at TDC... Then pour a tiny amount of oil all around the top of the rings, then rotate to BDC, and wipe the crap off the walls.. Then flip your motor over and make sure you clean any brake cleaner than may have gotten past the rings..
This will ensure you dont get any crud stuck where it dont belong
Old Oct 5, 2006 | 08:09 PM
s346k's Avatar
just bolt everything together and hit it with a 10lb bottle's worth of 150 shots, that will clean it off nicely.
Old Oct 6, 2006 | 09:27 AM
Billdog350's Avatar
I used Permatex gasekt remover. That stuff is SICK...it bubbles up and looks like paint stripper when you spray it on. However you can just wipe away the carbon and crap when its done....just wear gloves!!
Old Oct 6, 2006 | 09:35 AM
PREDATOR-Z's Avatar
Like i said just be careful using any solvent that would be damaging to the soft aluminum of the pistons
Old Oct 6, 2006 | 03:55 PM
Bad30th's Avatar
Also be careful not to get any of the pad residue and spray cleaner down into the coolant passages.
A green scotchbrite pad and some carb cleaner will take it right off.
Rob (Bad30th)
Old Oct 6, 2006 | 04:07 PM
LostCauseZ06's Avatar
or... just put the motor back together, run some seafoam through it, and call it a day
Old Oct 6, 2006 | 04:43 PM
BrianC98Z28's Avatar
i like the nitrous route of cleaning
