Patrick G and predatorZ Oh please help me..
Old Nov 12, 2006 | 05:28 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by Wyckedcamaro
towed it out of the shop and brought it to another shop. Currently letting them diagnose the problem.
thanks though!
So, the mechanic couldn't figure it out? What did they do that could not determine anything?
Old Nov 12, 2006 | 05:32 PM
Wyckedcamaro's Avatar
they did not know the preload information and really didnt want to check it out.
They did not know the coil bind..
They put parts in which they recommended to me and then didnt really adjust them. They offered to tear down the motor again after they tried to put straigh 50 weight oil in to shut her up. After that little trick from them.. I decided I didnt want them touching my car anymore.
I brought it to a older shop I used to use.
We shall see.
Old Nov 12, 2006 | 05:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, sounds like they need to take their sign down and put one up that says "Parts Store". Sorry to hear that you got tail ended like that.
Old Nov 12, 2006 | 06:08 PM
no problem. I live and learn.
If I knew more about cars and mechanical work.. i could save myself a TON of money. But unfortunately, I just want to go fast and I dont know much about mechanical stuff so I lay prey to ******** out there.
Old Nov 13, 2006 | 07:00 PM
GuitsBoy's Avatar
Ask them for the actual specs, as the other said, the lifter preload specifically. Preferably numbers for both intake and exhaust if theyre on different lobes as I think pred said. If youre in the .070 - .100 range, look elsewhere for your noise issues, but if youre closer to like .020 preload, some longer rods might help. A lot of shops recommend pushrods a little short. I dont know if they just want to err on the side of caution or what, but it happens quite frequently.
