well I started the cam install but one problem
Old Oct 8, 2006 | 09:44 PM
mvvette97's Avatar
Default well I started the cam install but one problem
Is there a special three arm puller for the damper or will most work? The one I have must be too big because I can't get the arms hooked on the damper.
Old Oct 8, 2006 | 09:59 PM
rollinna65's Avatar
When I was getting mine off I tried this really small black one that was recommended for LS1s but couldn't get it to work. I ended up just using one of the medium sized pullers they happened to have at the place I was doing the swap.
Old Oct 9, 2006 | 08:09 AM
vettenuts's Avatar
I rented it from Autozone.
Old Oct 9, 2006 | 09:55 AM
01formula6's Avatar
I rented the 3 arm puller from Autozone, works pretty good...and it's free.
Old Oct 9, 2006 | 11:26 AM
WS6FTW's Avatar
When you go there, tell them you need a puller for a chrysler. I went and asked them for a three armed puller, and they looked at me like I was on crack.
Old Oct 9, 2006 | 11:32 AM
99C5JA's Avatar
I'm in Ankeny and have a puller if you get desparate.
Old Oct 9, 2006 | 12:09 PM
mvvette97's Avatar
Thanks. I will see what i can find but if I can't find one i will let you know.
Old Oct 9, 2006 | 01:00 PM
BriGuy's Avatar
I have always gone to Auto Zone or Advanced Auto and told them I needed a 5 ton 3 jaw pulley puller. Always worked like a champ.
Old Oct 9, 2006 | 01:17 PM
Z'mnypit's Avatar
I bought one from sears, its was about $75 or so but has been well worth the money. Its a perfect fit...
Old Oct 9, 2006 | 01:40 PM
yak's Avatar
yak
+1 the sears three jaw fits perfect.
