Is there a stroker kit available for the 6.0?
Old Jan 24, 2003 | 05:02 PM
Black Sunshine/ 00SS's Avatar
Default Is there a stroker kit available for the 6.0?
Or does the standard LS1 stroker kit work?
Old Jan 24, 2003 | 07:30 PM
strokedls1's Avatar
Default Re: Is there a stroker kit available for the 6.0?
Standard size works, but the pistons are a custom order since you will have the bigger bore. How much bigger is up to you. 4.060 is the most you should bore it to.
