High static compression
Old Oct 11, 2006 | 12:49 PM
jpr210's Avatar
Default High static compression
Im trying to narrow down the operation (low in power) of my engine and Im getting 228 psi of static compression on my LS1. My Voodoo cam card says that it has 4 degrees of advance at the 109 ctrline but I dont know if this is the cause of the high stat comp number. Lunati has recommended to retard the cam timing 4 degrees. Does this sound right?
Thanks
Jpr
Old Oct 12, 2006 | 09:54 AM
jpr210's Avatar
bump
Jpr
