Torque Specs
Old Oct 12, 2006 | 12:45 AM
Phantomhp's Avatar
Default Torque Specs
Hey,
I searched but nothing really shows up. Not sure if the search is working or if I am not using very good key words.
Anyways, I have a 98 LS1 and I saw on LS1howto all the torque specs but they say they are for the 2000 model. Are the 2000 torque specs the same as the 98? Also what is the sequence on the head bolts?
I have this diagram so if correct I might have the answer to my sequence question.
Thanks,
Mike
Old Oct 12, 2006 | 12:55 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
98-00 are the same specs
01-02 are the same specs
I have the numbers for both if needed
Old Oct 12, 2006 | 01:32 AM
Phantomhp's Avatar
oh ok,
So the specs on LS1howto.com would be fine from an 00 then.
Just in case if you dont mind sending me the specs for a 98 I would appreciate it.
Thanks,
Mike
Old Oct 12, 2006 | 05:54 AM
PREDATOR-Z's Avatar
Same, same
