Max Lift for the LS1
What is the max lift for a stock LS1 head? I have a FMS F10-12 with 228/228 - .575/.575 and wanted to go with Harland Sharp 1.8 roller rockers. I've upgraded the valvetrain when I did the cam install but with these rockers it will bring the lift to .609. Will I have enough piston to valve clearance and will the rockers clear the valve covers or do I need to get spacers?
Thanks for the help in advance!
"Due to the fast ramp rate of this camshaft, the use of 1.8 rockers is not recommended."
I'd say anything with fast ramp rates, like XE-R lobes, stick with a stock rocker ratio.
