weird idling problem
Old Oct 12, 2006 | 04:47 PM
ls1marine's Avatar
Default weird idling problem
ok so last time i was at the track in between runs i was in the pits and all of a sudden my car started idling at 1900 rpm and the only way it would stop is if i let off the clutch and it then it would go back down.....also i broke an axel and my alternator stopped working.......whats going on with my car
Old Oct 12, 2006 | 06:33 PM
malott442's Avatar
WOW. Sounds like fun. Well for the obvious first...... Axles eat their own **** with slicks, not to mention laughing gas and slicks....... so boo on you for not dishing out 200 for a pair.
The alternator, if still not working..... Sounds dead. Spinning an alternator at a track up past 6k burns the brushes. If it isn't dead there is one fuse under the dash and one under the hood. Plus plugs. OR maybe your gauge died. Unlikely but possible. If you have a multimeter, do a voltage check, and also resistance across the alt positive out and the body of the alternator.
Old Oct 12, 2006 | 06:36 PM
malott442's Avatar
The idle. My car did the same thing the other day when a cell in my battery died. I had to get it jumped to get it to the store.... and on the way the idle was at 550, vs. 800. I pulled my AIT cheater resistors out and plugged the stock sensor in. The idle stabilized itself in about 15 minutes, right at the parts store.......
I have a slight suspicion that when you fix the alternator, your idle might start to feel less like a 92 Geo Metro with a vaccuum leak.. Good luck.
Old Oct 12, 2006 | 10:19 PM
ls1marine's Avatar
thanks alot man i hope fixing the alt fixes the idle problem
Old Oct 13, 2006 | 05:21 AM
ls1marine's Avatar
any other ideas
