Carbed LS6 power #'s
Old Oct 17, 2006 | 07:27 PM
Davy_Baby9's Avatar
Default Carbed LS6 power #'s
Can someone give me an idea on power output of the LS6 that I am building? Here are the basics...
LS6 block
Stock rods and pistons
Stock crank
Sealed Power Bearings
Aftermarket Rod Bolts
MS4 cam, 112 LSA
Precision Race Springs
Stock LS6 heads
Edelbrock Performer Carb Intake
MSD ignition to run ignition, timing
DEMON 750cfm Carb
I really have no idea. I was thinking in the 450 ish crank HP level. Also I am using the carb setup because the motor is going into a non-lsx vehicle and this makes it a hell of alot easier.
Old Oct 17, 2006 | 08:19 PM
Davy_Baby9's Avatar
I should of titled this thread differently because when you guys see "carb", you get all weird
Old Oct 17, 2006 | 08:21 PM
Marc 85Z28's Avatar
Add about 5-7% more to what you think it would make with a FAST setup.
And with the price of ported stock castings these days, why bother with stock heads?
Old Oct 17, 2006 | 08:31 PM
Bandit28's Avatar
port those head and develop some real good power numbers
Old Oct 18, 2006 | 06:19 AM
Davy_Baby9's Avatar
Yea, I guess you guys are right though. After adding up the cost, it would only be about 200 bucks more to actually get a brand new set of CNC Ls6 heads with .660 springs then it would be to buy used heads then buy a spring kit.
So would I be pushing the same power that an Injected LS6 would make? Around 400rwhp?
Old Oct 18, 2006 | 08:59 AM
SPLATT's Avatar
probabaly a little more. sounds pretty stout with the ms4 and demon. what type of vehicle is it going into?
Old Oct 18, 2006 | 11:07 AM
Davy_Baby9's Avatar
91 S10 RCSB, 2wd. It should be a stout little package. It should way as much or less than a C5 vette, so the only thing I'm actually worried about in a s10 is traction
