Squeaking noises
I had a new z06 clutch disc, pressure plate, flywheel, and slave cylinder put in my 02 ws6 about 6000 miles ago. About 3000 miles ago, I started hearing this squeaking noise when I let out the clutch pedal and starting rolling out of 1st gear and also when I step semi-hard on the gas in low gears. Sounds like it's coming from clutch/transmission. Thought perhaps it was the throwout bearing but I come to find out that the slave cylinder has a new throwout bearing included. Any ideas what this could be? The squeaking has gotten worse over the last couple of months and its not when i'm going over bumps, etc.
