Where to find 3.898 bore head gaskets?
Old Oct 17, 2006 | 07:57 PM
Lurius's Avatar
Default Where to find 3.898 bore head gaskets?
Im looking for some good head gaskets for a 3.898 bore. prefer somewhere between thickness of .042 to .05 compressed. Cant find any for the life of me. The material isnt too important as long as its designed for high performance applications.
Let me know if yall see any!
-Lurius
Old Oct 17, 2006 | 09:10 PM
ArcticZ28's Avatar
Cometic makes a 3.910 gaskets in those thicknesses.
http://www.texas-speed.com/shop/item...d=602&catid=36
Old Oct 17, 2006 | 10:33 PM
Beast96Z's Avatar
Yep, cometics or stock replacements.
Old Oct 18, 2006 | 04:26 AM
Lurius's Avatar
What thickness are the stock MLS replacements? Thats one of the things I culdent find anywhere.
Thanks again!
-Lurius
PS: At what kind of power should I look to upgrade from stock gaskets? Im planning an engine build up and am trying to make sure ive got all the parts available to me, and that I can get the right CR before I make any purchases. Thanks!
Old Oct 18, 2006 | 08:33 AM
ArcticZ28's Avatar
.052-.054 compressed. Many people are running 4-500 rwhp on stock head gaskets. It's mainly more of a concern when going forced induction or nitrous to upgrade.
Old Oct 18, 2006 | 09:57 AM
yak's Avatar
yak
does gm make gaskets that are any thinner than the .051?
Old Oct 18, 2006 | 10:12 AM
ArcticZ28's Avatar
negative
Old Oct 18, 2006 | 11:35 AM
1320 killer's Avatar
you can call www.cometic.com and they have a mls gasket in a 3.910 bore in any thickness you need. you want to go a little bigger on the bore of the gasket to give yourself a little room because of the torque specs.
Old Oct 18, 2006 | 04:13 PM
Lurius's Avatar
Ah.. I will be using nitrous, but under a 200 shot, and the engine wont likely make more than 350hp anyways. Think this will be a situation I should upgrade to the cometics then?
-Lurius
Old Oct 18, 2006 | 04:29 PM
ArcticZ28's Avatar
I would say so.
Old Oct 18, 2006 | 07:47 PM
Lurius's Avatar
Looking around looks like only good options are the cometics. 150$ a pair though, damn lol. Im not used to gaskets being so pricey!
Thanks a lot guys, looks like I can end up with an even 10:1 CR for this engine, should work out great!
-Lurius
Old Oct 18, 2006 | 09:26 PM
ArcticZ28's Avatar
Also keep in mind the gaskets are reuseable unlike the stock ones.
