LS6 Heads and a T rex
Old Oct 17, 2006 | 08:04 PM
chuckyt1's Avatar
Default LS6 Heads and a T rex
Was going to go with a T rex and my stock 241 heads, but I ended up buying a set of LS6 (243 casting) heads from another member. Quesion is - Anyone running this H/C combo? Any PTV issues? And, who does the best head porting in the Chicago area (NW Burbs)?
Thanks in advance...
Old Oct 20, 2006 | 09:55 PM
LS6GT's Avatar
Default ptv clearance
I called thunder racing and they said it would be fine but when i asked them what clearance would be they said not much at all. like .040 i am doing the same set up with a carb and i am pretty sure i am going to fly cut.
Old Oct 23, 2006 | 11:34 AM
chuckyt1's Avatar
Thanks, let me know how it goes...
Old Oct 23, 2006 | 12:51 PM
DONAIMIAN's Avatar
With the heads being off the car id flycut anyways.
Old Oct 23, 2006 | 07:47 PM
LS144's Avatar
I have a buddy wit ha trex and stock 241 heads that are slightly worked. His car pulls very hard and sounds incredible.
Just dont flycut to much. The stock pistons are only somewhere around 250 thousanths deep. You can get you a can of play do put it on your pistons and set your heads on and turn your harmonic balancer, let it dry then measure the depth.
Old Oct 23, 2006 | 07:56 PM
DONAIMIAN's Avatar
Well yeah its still a good idea to clay the heads but what im getting at is he has no room for a missed shift, thats why he should flycut regaurdless.
Old Oct 23, 2006 | 08:31 PM
chuckyt1's Avatar
I will clay the setup since I don't have a caliper and setup springs. Just kinda wondered if anyone has run this combo. Fly cutting looks like it might be a pita... Guess I'll have to waste one of my 241 heads...
Old Oct 23, 2006 | 08:36 PM
bww3588's Avatar
why would you have to waste one of your stockers?
Old Oct 23, 2006 | 09:04 PM
chuckyt1's Avatar
Maybe I don't, I haven't done any fly cutting before but I thought that you needed a head to use ase a "guide". Guess maybe you could just pop the seat out? Still learning...
