Which lsa for torquer v3, m6?
Old Oct 22, 2006 | 11:10 PM
Bader-X's Avatar
Thanks a lot PREDATOR-Z ^_^
that`s powerband wise between a 112+2 and 110
assuming I understood some of what you said a 112+2 is better powerband wise than a 112+0 .... because I wanted to know the difference between a 112+0 and a 112+2 (is a 112+0 a 112 ICL?)
actually I was thinking like smooth cam such as a stealth where they claim a near stock idle ... if it was on a 116 .... and you ordered it on a 116+4 or say +6 if possible will it idle close to a a 112 and a 110 respectivly?
what about a 110-4 and a 112+4 wich one will idle better and begining of the powerband where they smoth and pull hard will rise or drop from the RPM if they were 110+0 and 112+0 (I only know the t-rex is pulling hard in 3k or 3.5k and up in a friends car and it`s on a 109.8+- I don`t know lsa)
Old Oct 23, 2006 | 02:55 AM
PREDATOR-Z's Avatar
Stunningman, I replied to PM.
Bader-X
It is a bit more complicated to explain. Perhaps if you read JRP "guide to Camshafts" sticky, you could then understand the dynamics of a cam a bit more.
A 116+4 will not idle like a 112 of the same duration.
Idle is relative to overlap. More overlap=more lope and more power (up to a certain degree).
Overlap is calculated like this:
{(int DUR+exh DUR)/2 - (2XLSA)}= * overlap
+ (positive) overlap means more lopey while - (negative) is more Stealth
Old Oct 23, 2006 | 03:22 AM
msgZ28's Avatar
Devil Dog, OohRah!
So cam expert people out there, how much, if any, advance/retard should I have put on my cam when it is installed? V.3 of course. PatrickG said 4 degrees of advance for cam only, I just want to verify this before I bug TSP.
EDIT: Also, will 4 degrees of advance change the idle sound at all? I want the cam to sound its best and frighten little children.
Old Oct 23, 2006 | 05:02 AM
PREDATOR-Z's Avatar
The reason he suggested +4 cam only is to make it more exhaust biased and increase DCR (in a stock head /ratio combo)
Just check with TSP first if 111+4 will fit without flycutting.
Idle lope remains unchanged by advancing or retarding a cam as amount of overlap is unnafected.
Mark
Old Oct 23, 2006 | 05:11 AM
msgZ28's Avatar
Devil Dog, OohRah!
Great! Thanks for the info buddy.
Old Nov 14, 2006 | 10:54 PM
qwikz28's Avatar
i hate to bump such an old thread, but i figured it would be more beneficial then making a new one.
has anyone advanced this cam? im just wondering what p/v clearance is like on these cams with stock size valves and what people have done with these cams and they're experiences. i believe the cams are 111 + 1
Old Nov 15, 2006 | 09:41 PM
Fratsit's Avatar
Update for me....got EFIlive and an Innovate LM1.
Had her on the dyno yesterday. With a conservative tune I made 385/380. This is with the LS1 intake and no UD pulley, other mods in sig. I can email the graph on request. Nice torque down low.
I still have some issues to work out with the tune....hey...I'm learning here Dyno shop wants to fail the MAF and do a Speed Density tune so I am heading back after Thanksgiving. Logging my butt off for now.
R/
Frat
Old Nov 16, 2006 | 02:24 PM
qwikz28's Avatar
anyone know about degreeing this cam? i could call TSP and find P/V clearance but i'd rather hear some real world experience
