Please double check my CR for me!
bore: 3.898
stroke: 3.622
stock 5.3 heads: 61cc
piston dish: -8cc
and gasket thickness is .050
Using a calculator I found on google its coming up to 9.996, so pretty much 10:1, which is my goal for the CR.
This calculator dosent ask for the deck height, though I have seen some that do. Is the deck height nessicary for calculating compression? I believe I read somewhere that the gen III engines use a - deck height, the piston extending past block very little to compress a little more. True?
Thanks a lot guys!
-Lurius
