Coolant after a head swap.
Old Oct 23, 2006 | 03:47 PM
AppleMac's Avatar
Default Coolant after a head swap.
Just put some new gaskets on...
What is the normal amount of time before you can stop adding coolant.
I am figuring thre are still small air bubbles in the system...
I originally filled with coolant, heat cycled filled with coolant again.
Then drove it 30 miles the next day. Filled coolant about 5 cap fulls
Then drove it 20 miles today. Filled coolant about 3 cap fulls..
Think this is normal? Just some air in the system? Thanks
Old Oct 23, 2006 | 03:59 PM
AppleMac's Avatar
This is on my LS2 with ET heads if that makes any difference.
Old Oct 23, 2006 | 05:27 PM
DaddySS's Avatar
Check for:
Coolant in oil, oil in coolant, coolant in exhaust and any leaks. Fill the recovery tank (after intial fill, heat cycle, top off) to full cold and then run it for a few days. Top the recovery tank (full cold) off again and then check it from time to time - you should be fine.
Old Oct 23, 2006 | 05:51 PM
DAVESS02's Avatar
Some gaskets require a retorque after heat cycling or they WILL leak. I've had this experience first hand. If you still suspect leaking after a retorque, GM makes coolant sealing tabs that some have had success with. Good luck!
Old Oct 23, 2006 | 06:40 PM
AppleMac's Avatar
I did the retorque after heat cycle. I guees I will just wait and see what happens.
I am hoping it is not a leak... I am probably just paranoid as I had a leak before.
Old Oct 24, 2006 | 05:43 PM
AppleMac's Avatar
35 miles today. 0 coolant loss! woot!
Old Oct 24, 2006 | 07:50 PM
DaddySS's Avatar
Excellent!
