Time to do cam & springs?
I did longtube headers in 3 days or so. One day of heavy labor and another two of just a few hours.
Also, do you think I should get the car on full coverage for a few days and take it driving so i can know a distinct before and after or will I know the difference for sure? I havent driven my ride in months.
I will worry about a tune after. Ideally, I want to have the car ready in the spring so I can hop in it and go!
. Pump has to come off if you're gonna do the chain, so if you plan on doing the chain plan on doing the pump. If you lived closer to GR I'd tell you to bring the car over and we'd bust it out, but Mt. Clemens is too far for me. The biggest PITA is the springs IMO. Especially if you're not using air to hold up the valves. Rolling each one to TDC sucks. Good luck. Mike
As for the oil pump, I dissassembled mine and put the body on, got the pick up tube in and was able to ensure the o-ring did not kink, and then centered it on the crank. A little oil on the gears and you are set. When you put the cover back on it gets torqued to 18 ft lbs. If you decide to take your pump apart you should still use a clean rags in the bottom of the pan in case you drop the bolt....and have a pen magnet handy as well. Thats what I used to get the bolt positioned.
Zspot98 has a good point with the springs. The TDC method will work just fine, however, I found it was easier to use air to hold the valves up.
LS1tech and LS1howto will come in handy during your install.
R/
Frat
