Should there be a coolant plug...
Old Oct 24, 2006 | 10:46 PM
Phil99vette's Avatar
7 Second Club
Default Should there be a coolant plug...
I've got a brand new 2004 ls6 block and wondering if it should have a coolant plug here.....directly above the oil galley pressed in plug...
Old Oct 25, 2006 | 12:08 AM
GOaT Cheese's Avatar
What's wrong with the one in your hand?
Old Oct 25, 2006 | 03:45 AM
prplhaz's Avatar
that's an oil galley plug, ain't it?
Old Oct 25, 2006 | 04:04 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The problem is: Whether it needs to go in there or stay in his hand and then be transported to the work bench. He is asking if there needs to be one in there.
Old Oct 25, 2006 | 09:42 AM
7 Second Club
Not the oil galley plug. The bolt hole directly above the oil galley plug that is pressed in...
Old Oct 26, 2006 | 11:09 AM
itsmeek's Avatar
The left hole is supply IN from the oil pump, 2nd hole is the plug for the casting hole and the 3rd threaded plug stays also.
Here is the lubrication schematic, I hope this helps:
There are slight variations in the other Gen 3 blocks, but nothing substantial like a coolant block plug missing.
This diagram is only for 2004.
