What exactly has to be changed to run an LS2 timing set?
Old Oct 26, 2006 | 06:26 AM
Gannet's Avatar
Default What exactly has to be changed to run an LS2 timing set?
I'd like to run an LS2 timing set on my '02 LS1. What exactly has to be changed to do that?
Old Oct 26, 2006 | 07:37 AM
slow trap's Avatar
i think you can reuse your gears if not worn which they shouldn't be and just get the ls2 chain.
Old Oct 27, 2006 | 04:16 PM
Gannet's Avatar
Anybody else?
Old Oct 27, 2006 | 04:54 PM
The stunningman's Avatar
pull the old one off put the LS2 one on. I have one the side plates are just thicker.
Old Oct 27, 2006 | 04:55 PM
Phoenix 5.7's Avatar
besides the chain, whats better?
I have a LS2 chain on my engine. much beefier than the LS1 chain. went straight in, no problem
Old Oct 27, 2006 | 05:01 PM
Gannet's Avatar
Cool beans. I like that idea better than shimming the oil pump. And I remember that Bill Jenkins said years ago that he preferred the single chains, and even the nylon gears ( ) because he said it led to less vibration and such (paraphrasing) being fed back into the valve motion.
Anyone who doesn't like the idea of running an LS2 chain on stock gears on a 600-or-so lift cam with a redline of 6700?
Thanks to all for the responses.
Old Oct 27, 2006 | 05:36 PM
hotrodrx7's Avatar
I'm running the LS2 chain with 6800 rpm redline and .602 lift. No problems so far.
