Lifter question
Old Nov 2, 2006 | 08:17 PM
Blksilvr's Avatar
Default Lifter question
What is the difference between the ls7 lifters and NEW GM Performance Parts Hydraulic Roller Lifter for LS-Engines
#SD8689
Can these lifters be used with the factory rockers
Old Nov 3, 2006 | 12:25 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
As long as they are not solid lifters you should be alright using them. It is a "stock" replacement. I have not seen them side by side however, so it is a shot in the dark, but I bet that they would work just fine. Most of these parts are interchangeable across the LSX platforms.
