ARP Head studs
Old Nov 6, 2006 | 06:22 PM
TurboGoat's Avatar
Default ARP Head studs
This is probably a dumb question but I dont know what part I need
my stock bolts that I took out of my 04 Ls1 gto are 3 sizes
the small bolts were 2" long
next size was a little over 4-3/8"
and the big ones were 6-1/2"
sooooo what part # do I need for ARP replacements studs
thanks for helping me out
Old Nov 6, 2006 | 06:24 PM
MiaSSmaro98's Avatar
just buy their kit
Old Nov 6, 2006 | 07:23 PM
Doc99SS's Avatar
I dont that you can use studs for the heads while the engine is still in the car, unless the GTO is alot different than the f-body.
Head studs stick way up from the engine block, and you must have lots of room above the end of the studs to be able to place the heads over the studs.
Old Nov 6, 2006 | 07:25 PM
smask04C5's Avatar
You can remove and install heads with studs in place.
Old Nov 6, 2006 | 07:27 PM
RUTAN TA's Avatar
I just built a head and cam 04 GTO and it used LS2 bolts.
Old Nov 6, 2006 | 07:30 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
I have a used set of arp head studs with 12 point nuts.I will sell them if your interested.I have one set of the 2004 and newer for sale and one set of the older style.
Old Nov 6, 2006 | 07:35 PM
SteveDoten@ARH's Avatar
Closed ex-Sponsor Account
in '04 GM changed the bolt length, ARP makes a specific kit for this ap. as stated
Old Nov 6, 2006 | 09:07 PM
Oh4GTO's Avatar
They did change the bolts in '04 but there are still GTo folks out there that require the longer bolts. I believe they changed that in Spring of '04.
Old Nov 7, 2006 | 07:18 AM
V6 Bird's Avatar
Look for my for sale thread. Ive got the ones you need, brand new in box, nuts still in plastic.
$225 shipped.
Old Nov 7, 2006 | 10:46 AM
oange ss's Avatar
what do you want for the older style set ?
Old Nov 7, 2006 | 01:22 PM
Zymosis's Avatar
I used ARP studs with the engine in the car (Note: 99 Camaro). Plenty of room. Just had to unbolt a few things extra to shift them out of the way.
