Is porting the TB worth it??
Old Nov 13, 2001 | 01:04 PM
Toxic Texan's Avatar
Default Re: Is porting the TB worth it??
What about TQ #'s
Old Nov 13, 2001 | 01:14 PM
Smoke_ur_5.0's Avatar
4rwtq
Old Nov 13, 2001 | 01:25 PM
topfig1's Avatar
The more your engine can breath ie cam and heads the more you benefit from the ported TB.
topfig
MGySgt USMC
Old Nov 13, 2001 | 02:51 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Yeah, I think the real benefits of a ported TB won’t show till the heads/cam level. Just like the LS6 intake really shines once you’ve got heads/cam.
Old Nov 13, 2001 | 03:59 PM
Steve98Z's Avatar
I could tell a differnce in the way my car responded after porting mine, as far as HP, I would say 3-8
Old Nov 13, 2001 | 04:18 PM
Damian's Avatar
LSX Mechanic
Definately worth it if you can do it yourself. I ported mine in my garage in about 30 minutes. I am not good at "feeling" mods, but it's common knowledge that opening up the passge for air is going to produce more power.
Josh
Old Nov 13, 2001 | 04:32 PM
NicD's Avatar
7 Second Club
It does work, so more importantly now is a procedure or write-up to do this. <img src="images/icons/smile.gif" border="0">
[ November 13, 2001: Message edited by: Nic00Z28M6 ]</p>
Old Nov 13, 2001 | 04:33 PM
Special K '01 WS6's Avatar
I had my '98's ported and I'm going to port the new one as soon as I get a dremel <img src="images/icons/smile.gif" border="0"> definatly worth it
Old Nov 13, 2001 | 05:15 PM
flyin red TA's Avatar
Every little bit helps.
I ported mine and couldn't tell a difference, but I have a lot of other things going already.
Old Nov 13, 2001 | 06:35 PM
02 'Hawk's Avatar
I've read of too many problems with it. I'd like to do back to back comparisons, switching one out with a friend and be able to run a wide band on it.
Then, and only then if it worked, would I be convinced.
Old Nov 13, 2001 | 08:29 PM
stevenmh's Avatar
I ported my TB and did the Fernco mod at the same time, and noticed a difference.
Old Nov 13, 2001 | 08:43 PM
Jason99T/A's Avatar
I can shift faster than you.
We picked up 5rwhp/4rwtq peak and up to 8rwhp in the midrange with a ported TB on a cam only car.
Jason
Old Nov 13, 2001 | 09:02 PM
J'sRamAir's Avatar
[quote]Originally posted by 02 'Hawk:
<strong>I've read of too many problems with it.</strong><hr></blockquote>
What kind of problems have you heard?
Old Nov 13, 2001 | 11:32 PM
NicD's Avatar
7 Second Club
OK people, how do you port your TB? What sections should I look to remove material from? Details?
Old Nov 13, 2001 | 11:53 PM
02 'Hawk's Avatar
[quote]Originally posted by J'sRamAir:
<strong>
What kind of problems have you heard?</strong><hr></blockquote>
pinging, too lean at WOT
buy auto tap -- should have one anyway though
MAF-T
fluctuating A/F at WOT from off-idle to shut down
hard to tune
trims fluctuating greatly to adjust.
you can't just stick a ported this or that on the car and expect it to produce + results. you have to look at the whole package. same thing we had to do back in the LT1 days. was a 58TB ever too much for your mods? yes, 1050 mono-blade? yes.
put my 58 on the car before i had the 396 done. it was too much for a hot-cammed/header/bolt on car. ran awful.
Be aware is all Im asking of you. It is a terrible thing to make changes and have nothing more than bought problems. make changes on data. Hell, borrow one and see what it does.
Hope this adds some perspective.
Chris
Old Nov 14, 2001 | 12:53 AM
Default Is porting the TB worth it??
What kind of gains are people seeing???
whoops had to add dyno #'s to sig. <img src="images/icons/grin.gif" border="0">
[ November 13, 2001: Message edited by: BADASSBOWTIE98 ]
[ November 13, 2001: Message edited by: BADASSBOWTIE98 ]</p>
Old Nov 14, 2001 | 12:59 AM
2K2 LS1's Avatar
Supposedly 7-8rwhp. i noticed a difference in putting one on my car.
I saw a 4rwhp increase on my car with just bolt ons.
Old Nov 14, 2001 | 07:58 AM
Y2K Camaro SS's Avatar
at our local dyno day a friend put on his 80mm BBK and lost 4 HP.
Old Nov 14, 2001 | 09:53 AM
Maybe someone could do a write up on before and after porting the TB. Dynoing and using autotap.
