Proper shift points for GM Hotcam.
Old Nov 13, 2001 | 10:10 PM
TA_2001's Avatar
Default Proper shift points for GM Hotcam.
For discussion.. I had this information
un-confirmed from gm techy people.
Hotcam peaks @ 6000rpms, when installed dot-to-dot.
After peaking @ 6000rpms, the power does NOT drop off rapidly, so its
alright to hold
it out.
Ideal shift points would be ~6300 or 6400.
I think 6500 would be a little too long.
You'll feel your acceleration begin to slow.
If you degree it in @ 111, it'll peak at ~6200 or 6300rpms, and shift
points should be
~6500 or even 6600.
This would be the best setup for a M6 w/ 4.10's.
Old Nov 15, 2001 | 12:53 AM
JC's Avatar
JC
Default Re: Proper shift points for GM Hotcam.
My hotcam is installed dot to dot. And I stretch it out to 6500. Good for 115 trap speeds on a 2.0 60'
