View Poll Results: cam
ms3
45
45.45%
g5x4
54
54.55%
Voters: 99. You may not vote on this poll
ms3 or g5x4
Old Feb 4, 2007 | 01:05 PM
N4cer's Avatar
True.
Old Feb 5, 2007 | 02:41 PM
esoteric_path's Avatar
what are the exact specs on the G5X4, any flycutting required?
Old Feb 5, 2007 | 02:56 PM
purdueranger's Avatar
if you want to run a smaller cc head than stock, yes.
Specs, good luck on getting those.
Old Feb 5, 2007 | 03:08 PM
I have an LS6 block, 383 eagle crank.
AFR 205 Heads with a G5X3, looking for MAX power w/o flycutting my pistons as that will involved another teardown.
the G5X3 specs were "secret" and its well known its 234/242, hopefully somone can get an X4 measured soon...
Old Feb 5, 2007 | 03:41 PM
X4 doesn't follow the step like the X2 to X3.
Old Mar 8, 2007 | 08:39 AM
YellowMonster87's Avatar
What do you mean by that???
Old Mar 8, 2007 | 09:46 AM
N4cer's Avatar
He means the G5X2 is 232/240. And G5X3 is 234/242. People assumed that the G5X4 is a 236/244, which would follow the pattern. But it doesn't follow that "one step up" pattern.
Old Mar 8, 2007 | 10:27 AM
SLP4CamaroSS's Avatar
i ordered the g5x3 on a 112 lsa cam thanks guys
Old Mar 12, 2007 | 07:25 PM
bgardner88's Avatar
does anyone know if the G5X2 cam is 50 state emissions????
Old Mar 13, 2007 | 12:37 AM
PREDATOR-Z's Avatar
As far as I can gather:
X3>>> 234/242 112/114 LSA
MS3 >>> 237/242 choice of LSA (111/112/113)
X4 >>> 240/244 111LSA (Like a MS4 on XE-R or should I say MS4 is like a G5X4 but with LSK lobe on intake)
no way, but in some states where only OBDII code checks are done and no sniffer it could pass.
