What's the diffrence between LS6, 5.3L and 6.0L heads?
Old Nov 10, 2006 | 09:51 PM
kornfreak_401's Avatar
Question What's the diffrence between LS6, 5.3L and 6.0L heads?
Well I'm fixing to pick a set up along with the MS3 but I'm trying to learn how they work and what's good and what's better. So what's the big diffrence? Texas speed has these heads on sale and I personally think they are pretty good for the price?
PRC LS6 CNC Ported Heads
Compared to these. What do ya'll think?
PRC 220cc 5.3L Stage 2.5 CNC Ported Heads
What about these?
PRC 6.0L Stage 2.5 CNC Ported Heads
Any recommendations? thoughts?
Jerry
Old Nov 10, 2006 | 10:48 PM
SSilverSSurfer's Avatar
well the 5.3 heads flow more...i believe the those 6.0 heads are used on there stroker, 4"bore minimum i believe,
Old Nov 11, 2006 | 12:11 PM
bump.
Old Nov 11, 2006 | 01:53 PM
SHINER's Avatar
I might be wrong.
The LS6 heads have a more desirable combustion chamber/valve Angle blah blah
I would still go with some 2.5 stage 5.3L
I have stock 243 heads(LS6) and they maybe made a 10-12 rwhp diff.
Old Nov 12, 2006 | 02:16 PM
any other thoughts?
Old Nov 12, 2006 | 03:27 PM
chriswtx's Avatar
6.0L heads have 72cc chambers that will lower your compression. I just bought a used set of PRC LS6 2.5 heads. They were making 468rwhp on a 2002 Z06 with a Fast 90 and GX3 cam. Going to hand finish the ports before I install them on my car.
http://texas-speed.com/shop/item.asp...d=134&catid=40
5.3L stage 2.5 CNC ported cylinder heads are probably the best bang for the buck though.. .
Old Nov 12, 2006 | 03:54 PM
chriswtx's Avatar
Also with the 5.3L stage 2.5 CNC ported cylinder heads don't go crazy big with a cam. The large 2.04 valves require flycutting pistons if you go to big on a cam. If this is your daily driver and your only ride, keep it simple and don't go overboard with a large radical cam. You can make plenty of power with a medium sized cam...Stick with a cam like the Texas Speed Torquer 2 232/234 .595/.598 or the TSP XS Series Camshaft 233/239, .595"/.603" Camshaft and keep it on a 114LSA. They both should make 420+RWHP and drive pretty nice...
Old Nov 13, 2006 | 12:02 AM
so you think the 5.3L stage 2.5 CNC ported cylinder heads will work with the MS4?
Old Nov 13, 2006 | 12:28 AM
SatanzWS6's Avatar
+1 for that.
id like to know cuz im in the market for a set of heads that'll match the MS4.
Old Nov 13, 2006 | 06:31 AM
Texas Speed, will this work?
Old Nov 13, 2006 | 09:05 AM
chriswtx's Avatar
no, pretty sure Texas speed said the MS4 wont work with the large 2.04 valves without flycutting the pistons...
Old Nov 13, 2006 | 12:20 PM
yup, i thought so... just wanted to make sure
Old Nov 13, 2006 | 12:32 PM
DONAIMIAN's Avatar
Not trying to be a dick or anything, but you would get your answers a lot quicker if you were to just pick up the phone and call them.
Old Nov 13, 2006 | 12:43 PM
not at all man, i'm actually in class all morning and haven't had time to call. plus i want to get some feedback from ppl that have done this....
Old Nov 13, 2006 | 01:05 PM
DONAIMIAN's Avatar
Not too many, plus with all the miss-information in your other post about the MS4 and heads regauring weather it would fit or not I would hate to see you drop all that cash on parts that wont work together.
Old Nov 13, 2006 | 01:48 PM
EXACTLY. Don't want to mess up. I just want to get several things clarified before i do. BASICALLY MS4 + LS6 Stage 1 heads will work, period. MS4 +the other heads will NEED flycuting.
Old Nov 13, 2006 | 01:51 PM
LS1powerhouse02's Avatar
YOU SUCK JERRY!!!!.......that is all........
I wish i had money.
Old Nov 13, 2006 | 03:03 PM
LOL!!! What's a matter Brent, you scuurrd that I'll hand it to you again but harder and faster? J/K. Well it's still in the works but i'll let you know what i do...
Old Nov 13, 2006 | 03:15 PM
| Powered by Satan |'s Avatar
just do some quick searches in the external engine section/ls1-ls6 internal section, there are tons of people that add their info in there... and you will find some good info
Old Nov 13, 2006 | 04:14 PM
NaSSty Nate's Avatar
Your best bet is to pick up the phone and call Brian Tooley at T.E.A. (total engine airflow) he will spend as much time as you want on the phone with you and will get you the right set of heads for your budget and what you want the car to accomplish.
