Hot engine knock?
Old Nov 21, 2001 | 09:40 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Hot engine knock?
2001 TA Firehawk w/M6 5k miles
My car starts with no knock but when it warms up it has a slight knock in the motor,sounds like a lifter.(can here it at idle but not in the car)
Any ideas or past experiences?
Car is going to the dealer on monday for a pinion bearing and to take a look at the engine noise.
Old Nov 22, 2001 | 09:56 AM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: Hot engine knock?
Anyone?Going to the dealer Monday.Need some ammo.
Old Nov 22, 2001 | 04:59 PM
TA/30th 1002's Avatar
Here's some ammo for ya:
1) .. state your complaint
2) .. describe when you first noticed it
3) .. explain what the tech will have to do to
duplicate your complaint
Tech should:
1) .. verify complaint
2) .. pinpoint root cause
3) .. deem whether or not complaint justifies a
warrantable repair (these F-body's have
alot of charactor)
4) .. make repair
5) .. reaply step 1 to verify complaint is
satisfied
hope all goes well Mon ... 1002
BTW ... these rear ends do make a little noise, if you've got a bearing going away you'll have a little metal in the rear diff oil sample.
Old Nov 24, 2001 | 01:26 PM
orangeponcho's Avatar
ttt, same here a light tapping almost like a header leaking,but its coming from the bottom end when hot.anybody??
Old Apr 7, 2002 | 11:11 PM
warped alien's Avatar
I also get a knocking sound at times. But after time mine has got to the point where it happens even after I just start the car up. It seems to only happen at low speeds, and when the car shifts from 1st to 2nd. It tends to do it more if i let up off the gas like in stop and go traffic, and have to hit it again. Then I get a lovely knock sound, sometimes the car even moves like the rear end or tranny is slipping. Is this the same thing?
