Engine Buildup: The little stuff
Old Nov 21, 2001 | 09:50 AM
y2khawk's Avatar
Default Engine Buildup: The little stuff
2 motivations behind this thread.
first, to get a list of stuff/part numbers in one place for those interested in building their own motor.
and second, i'm build a motor and want to know <img src="images/icons/grin.gif" border="0">
We all know you need the big stuff, block, crank, pistons, rods, heads, cam.
but how about the little stuff. gaskets, fasteners, bearings, rings, etc.
first off, i know ARP is making main and head fasteners now
http://www.arp-bolts.com
head studs
hex nuts - 234-4110
12-point - 234-4316
main studs
234-5608
what have people used for bearings, mains and rods? Cam?
For the new multilayer head gaskets in '02, same for both heads.
12565390 for 5.7L
12565391 for 4.8/5.3L
12565392 for 6.0L
anybody else? <img src="images/icons/cool.gif" border="0"> <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
[ November 21, 2001: Message edited by: y2khawk ]</p>
Old Nov 21, 2001 | 03:09 PM
Plum Crazy Rob's Avatar
Default Re: Engine Buildup: The little stuff
Rod bearings are Small Block Chevy, take your pick. In my case,
Clevite 77
CB663P
I got GM main & cam bearings due to availability, but they cost about 3 times what you should pay even from a discount dealer.
GM:
88890525 Front 4 main bearings
12369542 Rear main
(I don't have the boxes from the cam brgs, those
were installed by the machine shop)
ARP & Katech have rod bolts, if you're using a stock rod.
Katech:
A2236
[ November 21, 2001: Message edited by: Plum Crazy Rob ]</p>
Old Nov 21, 2001 | 03:40 PM
ooblockxburneroo's Avatar
does anyone know of a lock to lock the balancer onto the crank. 2 of my friends have them on there ls1 jus wondering if anyone has heard of these? <img src="images/icons/confused.gif" border="0">
Old Nov 21, 2001 | 03:52 PM
y2khawk's Avatar
12453167 BEARING,CAM(POS. #1,5) QTY:1
12453168 BEARING,CAM(POS. #2,4) QTY:1
12453169 BEARING,CAM((POS. #3) QTY:1
GM cam bearings <img src="images/icons/smile.gif" border="0">
Old Nov 22, 2001 | 10:18 PM
y2khawk's Avatar
anything else <img src="images/icons/smile.gif" border="0">
how about some of the bigger stuff?
throw out random part numbers <img src="images/icons/grin.gif" border="0">
Old Nov 23, 2001 | 09:03 AM
Rings:
Sealed Power Plasma-Moly E938K
Custom Dished Pistons:
Made from JE 3914
Cam Bearings again:
Sealed Power 1888M
[ November 23, 2001: Message edited by: Plum Crazy Rob ]</p>
Old Nov 23, 2001 | 03:51 PM
383LQ4SS's Avatar
Pilot bearing for the back of the crank. That one cost me a day and is much easier to do on a stand.......Hmmmmm..what else?
Old Feb 14, 2002 | 01:09 PM
BLOWNMERO's Avatar
has anyone used those coated bearings from moreperformance. Ive already ordered a set, just wondering if anyone else has used them
Old Feb 14, 2002 | 02:25 PM
IndyZ28's Avatar
Wow, You pulled this one from way back there.
Old Feb 16, 2002 | 06:19 AM
ws6rufus's Avatar
Federal Mogul now makes Main Bearings.
152M approx $80 for the set.
<small>[ April 08, 2002, 07:24 AM: Message edited by: ws6rufus ]</small>
Old Feb 16, 2002 | 10:22 AM
sross's Avatar
[quote]Originally posted by 383LQ4SS:
<strong>Pilot bearing for the back of the crank. That one cost me a day and is much easier to do on a stand.......Hmmmmm..what else?</strong><hr></blockquote>
14061685
Old Feb 19, 2002 | 08:03 PM
A70camaro's Avatar
I just hunted down parts for my rebuild
I got valve seals from GM , taking them to
local parts supplier to crossover a aftermarket match.
engine bearings from Federal Mogul
ring set from SpeedPro
valve locks from federal mogul
1.430 springs , spring seat and retainers from Comp Cams
Cam from Comp Cams
Timing Chain from Comp Cams
Valves from Ferrea , local for me 10 miles away.
head gaskets are available from Mt gasket now
as well as GM and a custom gasket maker.
All other gaskets from GM
Main bolts and Head bolts available from GM
Studs available from ARP (expensive though)
Rocker Arms , Crane ,T&D ,Jesel (all very expensive)
Rods , various makers
Cranks ,Lunati , Cola (new)
Pistons various makers
I do have some part numbers for the aftermarket parts , but I cant list them now ,got to go
Old Apr 15, 2002 | 03:18 PM
wicked 98z's Avatar
TTT
any more details about the little stuff
Old Apr 15, 2002 | 08:22 PM
Scalpel's Avatar
Are the ARP head bolts TTY type bolts?
Old Apr 16, 2002 | 08:47 AM
Jax White TA's Avatar
The ARP "bolts" arent available yet. The studs are.
Old Apr 16, 2002 | 11:24 AM
Black Sunshine/ 00SS's Avatar
Just ordered from NAPA, #5976 & 5975, R & L head gaskets for 2001 LS1, half the price as GM.
