Cam question
Old Nov 11, 2006 | 02:07 PM
SSquid's Avatar
Default Cam question
Hey guys!!! Question.... I am about to buy a cam for my 00TA... has 97k on it... I want a REALLLLLL mean sounding cam... but that is still streetable where I dont need to install a different stall or **** like that... I know I should buy the cam and lifters right? Any suggestions and links to where I can get the package deal? Thanks guys!!!
Old Nov 11, 2006 | 03:43 PM
NviouSS's Avatar
is this your dd? i think a 226 or 228 would be good. you'll get some good power and still be pretty streetable. also you're going to want to relpace your oil pump and timing chain while you're at it.
Old Nov 11, 2006 | 03:49 PM
sidewayz28's Avatar
if u do lifters your going to have to take off the heads.. i would probably do it just cause u have 97k on the clock. but also u should probably get a stall before the cam dont ya think?
Old Nov 11, 2006 | 05:32 PM
SSquid's Avatar
any links on the cams you suggest Nvious?
Old Nov 11, 2006 | 05:36 PM
NviouSS's Avatar
check patriot/futral/texas speed sites for the cams
