Part # for short belt??
Old Nov 21, 2001 | 09:52 AM
ONYXSS's Avatar
Default Part # for short belt??
Available in a local autoparts store?
Thanks.
Old Nov 21, 2001 | 01:35 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Part # for short belt??
Assuming you have an underdrive crank pulley and a stock alternator pulley, you will need a 51.2" long, 6-rib belt.
Part number would be something like K06512 - belt part numbers are just the length in inches and the number of ribs. K06512 = 6 rib, 51.2"
A 51.5" will also work
Tony
Old Nov 21, 2001 | 01:38 PM
ONYXSS's Avatar
Tony, that's the setup I have.
Thanks a lot.
Dave
Old Nov 21, 2001 | 01:57 PM
ONYXSS's Avatar
After calling 2 stores, they both have 51 and 52" belts, but nothing in between. Will either of these work?
Old Nov 22, 2001 | 03:50 PM
99taws6's Avatar
get the 52".. That is what I run and have had no problems.. It is a tight fit, so I am glad I got that one not the smaller one..
Old Nov 22, 2001 | 07:25 PM
MechMan's Avatar
Which belt, if I do have the Alt pulley to?
