IAC counts close to 20 when warmed ??
Old Nov 21, 2001 | 02:36 PM
TA_2001's Avatar
Default IAC counts close to 20 when warmed ??
Is there a way I can measure this with a voltmeter??
I dont have autotap..
tia
Old Nov 21, 2001 | 07:00 PM
c4c5specialist's Avatar
Default Re: IAC counts close to 20 when warmed ??
Hi there,
You may, however, you will need to see a duty cycle, measured in HZ, and you must read the correct coil within the IAC wiring.
Bestto you, c4c5
