ABS after cam install
Old Nov 12, 2006 | 10:02 PM
WS6FTW's Avatar
Default ABS after cam install
Did a cam swap, and the abs light came on when I started it. Almost 100% certian it is because we pulled the steering shaft, and turned the igniton on and moved the car. The steering wheel audio controls do not work now either, so how do I go about re-setting this?
Old Nov 13, 2006 | 09:54 PM
WS6FTW's Avatar
ttt...should this be in the PCM fourm?
Old Nov 13, 2006 | 10:49 PM
ShevrolayZ28's Avatar
Check and make sure you haven't blown a fuse or two.
Old Nov 14, 2006 | 07:35 AM
WS6FTW's Avatar
All of the fuses in the pannel in the car were fine, are there any under the hood that control these two things?
Old Nov 14, 2006 | 11:30 AM
There is a fuse panel under the hood in the front on the driver's side. Also make sure all your grounds are secure.
Old Nov 14, 2006 | 12:25 PM
30thta436's Avatar
I assume you mean airbag light not anti-lock brakes light. Since your steering wheel controls don't work, you broke your SIR coil in the steering column. It is a coil that winds and unwinds when you turn the steering wheel. If you turned the steering wheel without the steerign shaft installed you probably broke it. You will have to tear apart the steering column to replace it. Good luck.
Old Nov 14, 2006 | 02:18 PM
WS6FTW's Avatar
Damn.....I'm going to see if the warranty will cover that one.
