Please post some tests I can do in my garage that will....
thanks
bob
bob
Pull plug wires off the coil packs one at a time
Record drop in idle speed after each pull,
Replace and repeat.
This will give you a rough idea of how each cylinder is performing, i.e., weak cylinders will not cause much of an rpm drop. Strong ones will.
Make sure the engine is fully warmed up, use insulated pliers or better yet, a special spark plug wire puller, made of plastic.
