SES light question
Old Nov 26, 2001 | 09:37 AM
98A4Z's Avatar
Default SES light question
friday afternoon i descreened my MAF , the car ran great all weekend, incuding a couple of good streetraces. sunday night while just cruising down the interstate, the SES light came on. does it usually take a couple of days for a code to trip the light if you have MAF problems? ive only had the car two weeks so i dont have an autotap yet.
Old Nov 26, 2001 | 10:13 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: SES light question
Could be a lean code.
Check to make sure you don't have a vacuum leak.
Old Nov 26, 2001 | 11:50 AM
98A4Z's Avatar
just drove the car to get lunch , after about a mile SES light goes off. who knows, i thought once the light comes on it was there until you reset it?
Old Nov 26, 2001 | 01:16 PM
98A4Z's Avatar
when the light goes away does that mean the car is fine, or does it store that code to be retrieved at a later time?
Old Nov 26, 2001 | 06:20 PM
c4c5specialist's Avatar
Hi there,
The codes will store for a minimum of 50 ignition cycles.
Then, if the fault does NOT present itself again, it will clear from PCM memory.Besttoyou, c4c5
Old Nov 27, 2001 | 12:25 AM
LS1Tech Co-Founder
No, SES lites can go off on their own.
