Symptoms of a cracked spark plug?
SO, I checked #6 and #8, did not take either of them all the way out, just one turn loose, then retightened. I tested #8 with my finger and it felt like I could turn the porcelain loose, then tighten it back up. I pulled #2 all the way out to find it's only the metal tip that can screw on and off, and it doesn't take much to do it. The porcelain part should have stayed still?
Does #8 sound cracked? Are those symtoms of something else like a real bad exhaust leak on the header? It just started a few weeks ago, and I did the headers in July. I'll probably just take #8 plug out tomorrow and see though I loathe getting to it.
