In need of some rings
Old Nov 14, 2006 | 04:30 PM
jlm44's Avatar
Default In need of some rings
I'm trying to find some rings and I am having a tuff time doing so. This is what I need and if anyone could help it would be greatly appriciated.
4.105 bore plus 0.005
1.5 1.5 3.00 mm
Moly or steel top and a standard tension oil ring
Thanks again, Jason
Old Nov 14, 2006 | 05:08 PM
JPH's Avatar
JPH
Total Seal, Mahle, Je, Speed Pro. You Name It, They Probably Got It.
Old Nov 14, 2006 | 07:16 PM
jlm44's Avatar
I've yet to find any that you have named with a 4.105 plus 0.005
I haven't looked at Total Seal yet but that is what I'm going to do right now.
Old Nov 14, 2006 | 07:17 PM
jlm44's Avatar
plus it needs to be
1.5 1.5 3.00 mm
Old Nov 14, 2006 | 07:57 PM
jlm44's Avatar
No luck with total seal
Old Nov 14, 2006 | 09:51 PM
jlm44's Avatar
Thanks JPH for you imput...I'm still searching
Is there anyone else out there that can help me?
Old Nov 14, 2006 | 09:53 PM
Sean Collins's Avatar
The know it all's know it all
Speed Pro makes a few 4.1xxx size rings in metric thin sizes.Who made the pistons? that would be the first place i would go for rings. 4.1xxx is what alot of the newer ford guys are running might wanna check out some mustang parts vendors.
Old Nov 15, 2006 | 12:03 AM
jlm44's Avatar
There Ross pistons and I tried calling them but I was to late so I plan on calling them tomorrow
Old Nov 15, 2006 | 11:34 AM
JPH's Avatar
JPH
Yeah That Is An Odd Bore Size, You Might Try Grant Piston Rings, Either Way Most Of These Companys Can Make You What You Want, But Damn, I Think There Is A Pretty Good Wait Time. I Have Had Total Seal Make Rings Before, Got Lucky, And It Onle Took Them A Week. If You Do End Up Going With Total Seal, Ask For Billy, He Can Help You Out With About Anything You Need.
Old Nov 15, 2006 | 07:29 PM
jlm44's Avatar
Thanks bro! I'll do that.....I just can't believe that ross would make this piston which wasn't custom and not tell me that no one makes rings for it. It's kind of retarded if you ask me.
Thanks everyone for your help again I truly do appriciate it.
