cam swap
Old Nov 16, 2006 | 06:17 PM
LS1_Z28's Avatar
Default cam swap
I have a 99 Silverado with the 4.8L in it and also a 2000 Z28 Camaro that I have took the stock cam out of and upgraded a little. I was wondering if anyone could tell me the specs on the 99 4.8L and the specs on the 2000 Camaro cam. Im off work this week and have nothing better to do than swap out the 4.8L cam with my stock cam and springs out of the camaro. Also I need to ask if everything is compatible as far as the cam and springs. Thanks for your time I used search but came up empty handed.
David
Old Nov 16, 2006 | 11:46 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Everything should be compatible, but you qare going to do that work for little to no gain. I would consider it if it was a ZO6 or an LS6 cam, but not the low duration/lift stocker.
Old Nov 17, 2006 | 01:39 AM
00SS!'s Avatar
4.8=191/190 .457/.466 115.5
5.7=198/209 .500/.500 119.5
Last edited by 00SS!; Nov 17, 2006 at 01:41 AM. Reason: edit for fat finger-correct #'s now
Old Nov 17, 2006 | 02:13 AM
5_02ls1's Avatar
dont know the 4.8 but the ls1 is:
202/210 .496/.496 116lsa if it helps any
Old Nov 17, 2006 | 02:14 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Well, there are 2 different LS1 grinds. Depending on the year you have it will vary.
A 2000 Z28 should have the lower duration cam.
Old Nov 17, 2006 | 02:15 AM
5_02ls1's Avatar
Default not accurate
these nombers are not accurate do more research
Old Nov 17, 2006 | 02:17 AM
5_02ls1's Avatar
Default 2000
A 2000 Z28 should have this cam: 198/209 .500/.500 119.5
he said it was a 2ooo. the lift and duration dropped in 01 but the ls6 intake was added.
Old Nov 17, 2006 | 02:18 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Was it 01? I thought that the 98-99 had a slightly bigger grind.
Old Nov 17, 2006 | 02:31 AM
00SS!'s Avatar
99 4.8 GM part #12560966 has those specs
00 5.7 GM part #12560965 has those specs
01-02 5.7 changed to GM part #12561721 196/207 .467/.479 116
want more research?
