Please Help Piston
Old Nov 17, 2006 | 12:09 PM
fstls1camaro's Avatar
Default Please Help Piston
a bolt came off my throttle body and went into the motor and chewed up the pston a little bit i dont money right now to fix will it mess anything if i put new heads on it and leave the pistons.
Old Nov 18, 2006 | 12:55 PM
GOaT Cheese's Avatar
The problem is possible block damage or bent rod, I've seen both occur when a bolt is swallowed.
Old Nov 18, 2006 | 03:41 PM
Jake@EPP's Avatar
If possible could you post pictures of both the piston and head of that cylinder.
Old Nov 18, 2006 | 03:45 PM
Asmodeus's Avatar
yeah, a lot of IF'S with something like this.
