trick to getting oil pump on???
Old Nov 27, 2006 | 08:57 AM
Steve Burger's Avatar
LS1TECH Sponsor
The easiest way to install the pump is to use an old crank sprocket. Get it on the old one, slide it on the crank, line it up, push it on the new sprocket. Takes less than 2 min.
Old Nov 27, 2006 | 09:41 AM
Fratsit's Avatar
Nice... I did not think of that one.
Thanks for the tip.
R/
Frat
Old Nov 27, 2006 | 09:42 AM
TWISTEDTA's Avatar
Since i had to insall the crank gear it self, i slightly bent the edges to it, so i had to very lightly sand them down... It slipped right in after that
Old Nov 27, 2006 | 12:19 PM
wssexorz's Avatar
hmmm the fishing line is a really good idea ... never thought about that ... will try that tonight if i can find some ... hahaha ....
hopefully after work tonight will try and get that oil pump on ... then can continue to get rest done asap
Old Nov 27, 2006 | 11:13 PM
wssexorz's Avatar
update, spent a lil time under the trans am tonight ... got pissed off ... found about 8-9 10 mm bolts ... took front two out all the way ... loosened next two a bunch ... and then as i went back i didn't loosen them as much and the backs are just barley loose ... i used a crow bar and lightly tried to pull down the oil pan to get the 1 to 1.5 inch clearance and it just wouldn't drop ... it would move but not stay down ... what am i doing wrong??? it just doesn't seem possible to get the oil pump on without getting the pan down for more clearance on that pick-up tube bolt ...
getting really frustrated with why i even changed the oil pump anyway
Old Nov 28, 2006 | 07:54 AM
DirtyJohn's Avatar
Make sure your getting all the oil pan bolts, as well as the two bolts on the transmission bell housing, they thread toward the front of the car instead of up like the rest of the oil pan bolts. Alot of people forget those.
I think they're 13mm but it could be different on your car.
You'll remove them completely to get the clearance you need.
Old Nov 28, 2006 | 08:11 AM
wssexorz's Avatar
okay thanks john ... yeah i was looking at those and wondering if they would be needed to take off .... those were questionable for me
also if i do take those off ALL THE WAY ... and just loosen the rest ... will it drop enough for me to do this??? is this a smart thing to do without draining all the oil out? i have yet to do that .... didn't think it was needed to drain
Old Nov 28, 2006 | 08:29 AM
DirtyJohn's Avatar
I did it, its in the ls1howto writeup.
You'll definately spill some oil so have a pan ready.
I was worried about having low pressure from removing the oil pump, and didn't want to compound things by doing a whole oil/filter swap at the same time, so I havn't drained the pan.
I might end up draining it but leaving the filter on, not sure if that will make a difference or not
I read, when putting stuff back on,
Thread all the oil pan bolts hand tight or so to seat the pan,
Then torque down the bell housing bolts to center and align the pan before you torque down the rest of the oil pan bolts.
That's what i've read on here anyway.
goodluck.
Old Nov 28, 2006 | 08:58 AM
wssexorz's Avatar
so you do reccoment draining or not draining??
Old Nov 28, 2006 | 12:06 PM
DirtyJohn's Avatar
I by no means have the experience to "recommend" anything, but I prob will drain it, just cause its been a while since my last change.
Old Nov 28, 2006 | 01:37 PM
wssexorz's Avatar
has only been a thousand or MAYBE two since my last change ... i guess it is about due time ... will probably just drain tonight, and then drop the pan tonight and get that stupid pump on ...
Old Nov 28, 2006 | 01:53 PM
  #32
pHEnomIC's Avatar
Drain the oil after your cam swap. Run the car a little bit then change it. Chances are, it got a lot of gunk in it during the swap.
Old Nov 28, 2006 | 02:44 PM
  #33
wssexorz's Avatar
i heard that also
only thing that sucks for me, i'm poor college kid .... that means i am going to be draining my oil now just to put on new oil pump ... then get the cam running ... drive it a lil bit ... and then do ANOTHER oil change ....
thing is .. my car has had royal purple and if i am not wrong, that stuff isn't cheap ... ithink i found it for like 70 dollars for a 12 quart case ...
Old Nov 28, 2006 | 02:59 PM
  #34
98Camarod's Avatar
Im a poor college kid too. Thats why I am getting nitrous for now HSW has a wet kit for 334.99
Old Nov 28, 2006 | 03:15 PM
  #35
wssexorz's Avatar
in order for me to get nitrous on my car, ever, is for somone to give me a GREAT explination why it would be a great power adder in my situation and be 100 percent safe on my motor
Old Nov 28, 2006 | 07:37 PM
  #36
wssexorz's Avatar
so i think i'm just going to drain the oil tonight ... drop pan as far as i can ... and hopefully get the oil pump on ... get oil pan back on ... and then finish cam install another night .... i wanna get my beast running again!!!
Old Nov 28, 2006 | 09:45 PM
  #37
98Camarod's Avatar
Just dont be retarded with it. Its not like you have to use it 100% of the time. Just a mere 75 shot is more than you will gain with your much more expensive cam swap. Dont forget, you have to get a tune too.
Old Nov 28, 2006 | 10:28 PM
  #38
wssexorz's Avatar
i know i hav eot get tune
update:
just got back from shop ... after draining, getting 2 housing bolts ... new oil pump was a BREEZE to put on .. woot
Old Nov 29, 2006 | 01:04 PM
  #39
Fratsit's Avatar
R/
Frat
Old Nov 29, 2006 | 02:00 PM
  #40
98Camarod's Avatar
Let us know the numbers when you get it tuned.
