Comp Cams timing chain?
Old Dec 5, 2001 | 05:52 PM
ws6rufus's Avatar
Default Comp Cams timing chain?
Is anybody using it? Is it a true dual roller chain? Its not just larger gears to take up the slack with a GM chain like the Cloyes is it?
Old Dec 5, 2001 | 08:15 PM
SpeedDemon's Avatar
Default Re: Comp Cams timing chain?
There are two Cloyes chains. One uses the factory chain and has billet gears and the other has the same gears and a jwiss chain, which is awesome. Comp sources their chains from Cloyes I believe.
Old Dec 5, 2001 | 08:20 PM
MelloYellow's Avatar
Ya. Throw away any chains marked 'RENOLD'. If you need a Jwis Kettin, Katech has them for around $80 or so.
Old Dec 5, 2001 | 09:52 PM
ws6rufus's Avatar
So does the Comp Cams set-up come with the jwiss chain or the renold chain?
Can the Cloyes set-up with jwiss chain be purchased as a set?
Old Dec 5, 2001 | 10:13 PM
The Cloyes '-AL' part number has the better chain. HARD to find anyone stocking it. Most often a special order. Expect a $200-250 premium for that p/n. It's better just to get the Cloyes 'A' gears, toss the RENOLD chain away and order a Jwis Kettin from Katech for $80.
Also, FWIW the Comp gears are Cloyes gears with one minor change which isn't important. Consider them Cloyes gears. Also, Katech has them cheaper at like $100 for the 'A' gears.
[ December 05, 2001: Message edited by: MelloYellow ]</p>
