THERMOSTAT QUESTION
Old Dec 6, 2001 | 02:00 PM
JDC LS1's Avatar
Default THERMOSTAT QUESTION
i have a 99 T/A and i was wondering if i got the 160 degree thermostat would i have to buy anything else to go along with it, like the manual switch to kick the cooling fans on, to make it work...would it hurt anything if thats all i put in for now, or will the car still run at 210 like usual b/c of the fans not set to kick on till 210...i have access to a tech 2 and was wondering if the tech 2 can change the temperature when the fans kick on like the hypertech can?? if i get the thermostat, what do ya'll suggest i should get with the thermostat?? should i get the fan switch, do the throttle body coolant bypass, etc...
thanks...JOSH <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Old Dec 6, 2001 | 02:05 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: THERMOSTAT QUESTION
TechII will not PERMANENTLY save ANY changes.
Colder t-stat is a good idea.
My car runs around 185F with my setup.
Old Dec 6, 2001 | 02:09 PM
TA_2001's Avatar
Here is some reading for you about temp..
http://ls1info.com/categories.php?op=newindex&catid=2
and some more..
[URL=http://ls1info.com/modules.php?op=modload&name=Forum&file=viewtopic&t opic=32&forum=8&0]http://ls1info.com/modules.php?op=modload&name=Forum&file=viewtopic&t opic=32&forum=8&0[/ URL]
and a fan mod
http://ls1info.com/article.php?sid=171
[ December 06, 2001: Message edited by: TA_2001 ]</p>
Old Dec 6, 2001 | 02:22 PM
LIL SS's Avatar
Moderator
Here are a couple things for you to think about as well..
Thermostat:
http://www.tech-ls1.com/cgi-bin/ulti...c&f=1&t=000687
Fan switch:
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=1&t=000511
I have not done the thermostat trick yet. I have a 2001 car which comes stock with a 180* T-stat. So I don't think I need it yet. Car runs normally at 190*...
The write up GWJ gave me in the Fan switch thread is what I did.. It works excelent!! Hope this helps and saves you a few bucks..
