Need help predicting this cam
Old Nov 19, 2006 | 03:42 PM
squealingtires's Avatar
Default Need help predicting this cam
What should I expect from this setup with the engine specs below? Power estimates? Power band? Does anybody have anything close to this setup? How does the overlap in the cam look? Would your opinions change if up to a 200 nitrous hit were involved?
Comp XER @adv(287/289) @.050"(238/240) .604/.609 112+2
Seat Timing ......OPEN ............. CLOSE
INTAKE:......... 33.5 BTDC ........ 73.5 ABDC
EXHAUST:.......78.5 BBDC ......... 30.5 ATDC
OVERLAP 64 degrees
Engne Specs. with M6 transmission
Block: 4"bore, 4"stroke -->402ci -->Dynamic compression ratio 8.89:1
Heads: approx 345cfm intake and 240cfm exhaust
Intake: FAST 90/90
Exhuast: 1 3/4" LTs
Old Nov 20, 2006 | 08:51 AM
KilerTA's Avatar
Hey lets just install it and figure out whats gunna do that the best thing come on Squeal you know you want to lol
Old Nov 20, 2006 | 07:58 PM
no comments....well then. I was hoping for a last minute warning, a caution or some thumbs up.
Old Nov 21, 2006 | 09:41 AM
GuitsBoy's Avatar
Its tough to really ballpark it on a 402. its kind of a smallish cam, however those heads seem like they flow absurdly well, L92's? If so theres too little knowledge about them yet, but valve shrouding seems to be an issue.
