Cam duration and engine displacement
In a stock displacement engine, that would definitely be a large cam, but I have heard that this would not be bad with a larger displacement engine. Anyone know more about this?
[ December 07, 2001: Message edited by: WeatherGuy ]</p>
If you haven't already comitted to the engine then you have plenty of time to work out the specs.
<strong>Very streetable in my opinion. I'd consider something with duration between 230 and 240 to be somewhat streetable. Lift maybe in the low .600's. Just guessing. Talk to Jason and tell him what exactly you are looking for and he should be able to help.
If you haven't already comitted to the engine then you have plenty of time to work out the specs.</strong><hr></blockquote>
Thanks for the reply. I will be out there (at MTI) tomorrow replacing my POS stock rotors with Eradispeeds - I will be sure to talk with them about it. Generally, like most people, I want to get away with as much as I can and still have a daily driver.
Certainly a larger displacement engine will require more cam. Thats just a fact. I think the cam you listed would be [perfect] for a 422. However, if I was doing it, I would stick with a 114 LSA. Why; It will idle better... Period. Many folks like the 112 LSA becouse it gives slightly more mid-range torque/HP at the expense of idle quality and high RPM torque/HP.
Well, you will have all the torque/HP at mid-range you could ever want with that 422, and then some.
Put a 114 LSA in it, and at least have less PCM/idle problems and a 422 that will pull harder where it really starts to shine.... Towards the top of its rev limit.
Remember, its still a daily driver (I guess)
Just my opinion,
Ron
[ December 08, 2001: Message edited by: Kimchee and Rice ]</p>
I was told that this combo along with FLPs and a cutout should be able to get about 470 RWHP on the 422 <img src="images/icons/shocked.gif" border="0"> I am already drooling <img src="images/icons/grin.gif" border="0">
