ET Heads with 99893 springs
Old Nov 20, 2006 | 05:12 PM
SSPerformance's Avatar
Default ET Heads with 99893 springs
what are you guys runing for lifters?
What are these springs rated to?
I have a almost new set of comp oe replacemnets that i was planing on runing. my new cam will bid in the low 250s probly turning 7500.
Old Nov 21, 2006 | 06:10 AM
Fireball's Avatar
I ran crane OEM replacement lifters, and 3/8" pushrods on the intake valves (figured a stiffer pushrod on the heavier intake valves couldn't hurt)
Based on lift, you can set them up to go .660 pretty safely
I was turning upwards to 7500 without evidence of float with LSK lobes.
Old Nov 24, 2006 | 09:25 PM
anyone else that ran these heads what did u run for lifters...???
Old Nov 25, 2006 | 07:31 AM
JPH's Avatar
JPH
USING CRANE LIFTERS IN MY ENGINES.
#99893-16
SEAT PRESSURE=130LBS. AT 1.850
OPEN PRESSURE=402LBS. AT 1.150
MAX LIFT WITH THESE SPRINGS IS .710 W/.060 BEFORE COIL BIND
SPRING RATE=391
SPRING O.D.=1.460 (DOUBLE SPRING W/O DAMPNER)
Old Nov 25, 2006 | 10:02 AM
what did u use for a cam?
Old Nov 25, 2006 | 11:02 AM
JPH's Avatar
JPH
what heads (int. runner size), cubic inch, intake, a4 or m6, compression ratio, desired rpm range and hyd. or solid cam.
Old Nov 25, 2006 | 01:32 PM
245s
408
Edelbrock Vic Jr
a3
11.to1
7500
hyd roller
