Too Many Options!!!!
Old Nov 21, 2006 | 10:55 PM
ZMONSTER!'s Avatar
Default Too Many Options!!!!
Hey all! love the site and all of your respective opinions but its just too much! i will have about 5 to 7 thousand duckies to drop into a motor after my next deployment so the question is; can anyone out there give me a break down of what they have that works? i would ideally make between 450-500hp, no F.I. or juice, all motor.
Old Nov 21, 2006 | 11:28 PM
1999 SS's Avatar
after doing two H/C cars (about to do another with all the left over parts) and you having up to 7 grand to spend i would do a turbo setup and be done with it.
what car/motor are you runnin?
Old Nov 22, 2006 | 12:54 AM
-=Modified=-'s Avatar
My post deployment plans:
PRC LS6 CNC Ported Heads with competition CNC valve job and PRC double springs kit - 199-PRC1.0LS6 - $1299.99
Texas Speed Magic Stick 4 Camshaft -25-MS4 - $389.99
F.A.S.T. LSX 90mm Intake & P.T.M. 90mm Combo - 25-FPTM -$1075.00
ASP Harmonic Balancer Crank Pulley (I will also need new belts) - 19-948500 - $214.00
SLP 85mm Mass Air Flow Sensor Mass-Air-Flow Sensor, 2001-2002 LS1 High-Flow - 38-23062 - $174.99
Texas Speed & Performance Chromemoly Pushrods (standard length) - 25-7400 - $109.99
Total=$3263.96 All Texas-Speed. Waiting on Jason for the discounted final price.
Already have all suspension, LTs & exhaust and some intake modded.
Old Nov 22, 2006 | 03:17 PM
ZMONSTER!'s Avatar
Ive got an 02 z28, stock LS1
Old Nov 22, 2006 | 03:24 PM
Wheeler99WS6's Avatar
ASP Harmonic Balancer Pulley (I will also need new belts) - 19-948500 - $214.00
Most of these look pretty good, they should definitely put you close to your goal with a good tune
Old Nov 22, 2006 | 03:33 PM
cws T/A's Avatar
from the dyno results the TSP 2.5's will = more rwhp , but flycutting is required .
2.5's
https://ls1tech.com/forums/dynamometer-results-comparisons/539900-480rwhp-magic-stick-4-camshaft-prc-stage-2-5-ls6-fast-90-resullts.html
bigger cubes / not the best intake but you get the idea
https://ls1tech.com/forums/dynamometer-results-comparisons/609974-before-after-ls2-ms4-prc-stg-1-ls6-heads.html
Old Nov 22, 2006 | 10:09 PM
ZMONSTER!'s Avatar
how are you getting a discount?
Old Nov 22, 2006 | 10:10 PM
ZMONSTER!'s Avatar
2.5's
https://ls1tech.com/forums/showthread.php?t=539900
https://ls1tech.com/forums/showthread.php?t=609974
What do you mean by flycutting?
Old Nov 22, 2006 | 10:47 PM
cws T/A's Avatar
cutting valve reliefs in the stock flattop pistons
Old Nov 22, 2006 | 10:49 PM
Cop Car's Avatar
G5x4 and ported LS6 heads
Old Nov 23, 2006 | 01:34 AM
ZMONSTER!'s Avatar
will stock pistons and rods take that much power? or should i switch out my internals for something stronger?
