Cleaning ASSEMBLED Shortblock?
Old Nov 22, 2006 | 12:05 AM
Ferocity02's Avatar
Question Cleaning ASSEMBLED Shortblock?
I am going to be installing my stock shortblock soon and was wondering if there is a way to clean it without taking it apart. It had been sitting for a few weeks uncovered and I am sure there is crap in the oil galleys and in the rings. I was thinking of hosing it down, but then the bearings and rings would be starved of oil on first startup. Anyone have any suggestions? Thanks!
Old Nov 22, 2006 | 03:17 PM
Ferocity02's Avatar
Anyone?
Old Nov 22, 2006 | 05:04 PM
Mikey 97Z M6's Avatar
Well, short of stripping it down, as long as it was not contaminated with large particles/debris and was limited to just normal dust, you could just take an air nozzle w/compressed air to it and get in all the little crevices that you can with that. But if you can see larger debris sitting on it, I wouldn't take a chance, just strip it down and re-clean everything with some mineral spirits. The type of environment it was sitting in will play a big factor in how much it was contaminated. Can you see any surface rust on the cylinder walls?
My .02
Mike
Old Nov 23, 2006 | 11:56 AM
Ferocity02's Avatar
I was hoping there was a good way to oil the bearings after washing it even though it's all assembled.
Old Nov 23, 2006 | 12:07 PM
RiceKilla's Avatar
Wherever a gasket mates up I would clean with some acetone, mineral spirits tends to leave a film.
Old Nov 23, 2006 | 12:27 PM
Grimes's Avatar
don't use water to clean off the assembled block....
